Transmission Debacle
Old Sep 1, 2010 | 10:23 AM
sc99landrover's Avatar
4th Gear
Question Transmission Debacle
I am need of advice. The other day my wife was driving our 99 LR DII and it started to rev before shifting into 3rd gear. She later told me that earlier when she went to back up she heard a "clunk" sound. I had my friend who works at a transmission shop take a look and needless to say, I was informed that it needed a new transmission ($2000 for used, $3500 for rebuilt) Not sure which direction to go and for right now I have an expensive piece of lawn art. Any advice?
Old Sep 1, 2010 | 10:37 AM
Bundu's Avatar
Banned
Every Disco clunks, that is normal due to slop in the drive line. The ZF trannies are bullet proof, you don't need another one.
Have you ever replaced the oil in the tranny, transfer case and diffs?
If not then start with that, drain and replace the oil in all of them and also replace the oil filter in the tranny.
Replace the U joints in the front drive shaft, they are known to fail.
Clean the idle control valve and throttle body with carb cleaner.
Do the full 60K service on your truck.
Look in the How Tos at the top of this section for detailed instructions.
Old Sep 1, 2010 | 11:13 AM
4th Gear
Thank you for the advice. I will start with that and hopefully reslove the issue.
Old Sep 1, 2010 | 11:17 AM
If you want some help, send me your number and I'll walk you thru what to do.
Have you had any check engine or warning lights coming on lately, when was the tranny last serviced?
Old Sep 1, 2010 | 12:56 PM
4th Gear
Disco Mike,
No check engine lights or warning lights have come on. I do not know the last time the tranny was serviced. The previous owner did not disclose that (or didn't have it done) either way, it is probably time to do it anyway.
jmt
Jan 8, 2008 01:49 PM
