Transmission fail safe
Old Apr 17, 2012 | 08:00 AM
fyreles's Avatar
Default Transmission fail safe
First of all I did search and read the fail safe posts. I have a 2000 D2 and had the battery dis connect for an hour or so putting side posts for the winch on. About twenty minutes later trans is in the 3rd gear flashing lights mode, I read a post that asked about battery issues. Can someone shed some light....thanks
Old Apr 17, 2012 | 08:19 AM
drowssap's Avatar
if you battery volts get below 13.5 volt the tranny cpu goes into safe mode only allowing 3rd gear.
the problem 90% of the time is battery, alternator or ground related. Have the battery load tested, charging system checked and clean all your connections.
Im guessing you drained the battery playing with your new winch.
note i said 90% of the time the other 10% are a real PIA to find.
Old Apr 17, 2012 | 08:22 AM
fyreles's Avatar
If what you say is the issue, will this resolve with a charge or will I need this mode "cleared" some how, thanks
Old Apr 17, 2012 | 08:36 AM
You shouldn't need to recharge a battery after disconnecting it for an hour.
Go to your local parts store and have them do a free charging system test, the voltage has to be between 13.6 and 14.4 volts. If your battery is bad and with adding a winch, if you need a battery now is the time to buy a good 1000 CCA rated battery.
Old Apr 21, 2012 | 01:33 PM
fyreles's Avatar
My rover stayed in fail safe for three days then magically cleared when I was on my way to my friends shop to scan it.
When I did scan it the codes P1590 twice and P1884 showed up. But these lights have been on since purchase..
Old Apr 22, 2012 | 08:15 AM
Do you realize, driving in limp mode if a "HUGE" screw up, what let you to think it was OK
to drive in 3rd gear????????????????????????
Go get the charging system tested as you were told to before and see what the voltage is, then get back to us with the numbers.
Old Apr 22, 2012 | 06:52 PM
fyreles's Avatar
First off Mike, don't type angry. It is very counter productive.
Second, my rover is not my daily driver and the seven total miles in fail safe mode, five and a half of which was getting it home may not have caused permanent damage.
I'm not a rocket scientist but I understand that driving it in fail safe is harmful.
I did get on this forum for help but the hard core attitude is a turn off.
I am also on the paramedic/FF forums but don't hammer people when they ask a pedestrian question.
I also lived in Breckenridge for fifteen years so I have a basic understanding of the whole off road thing.......if you can help me great but I won't be bullied or subjected to angry sarcasm.
Old Apr 23, 2012 | 07:10 AM
drowssap's Avatar
did you find the source of your problem? it is not always charging system related in nature.
It took me approx. a month to find out my problem which was a connector under the console.
Mine is an everyday drive and in that month I put over 1200 miles on my truck, with speeds ranging from 30mph to 70mph and my tranny was no worse for the wear.
When i fixed the problem i drained the tranny and the fuild was a good a the day i put it in.
Driving in safe mode is not recomended, but should not be feared.
Old Apr 23, 2012 | 12:33 PM
fyreles's Avatar
The vehicle is driving well now. I will track down the codes. I plan to have the tranny serviced and see where I'm at then....
Old Apr 23, 2012 | 12:54 PM
hilltoppersx's Avatar
might as well rebuild the xyz and eliminate that as a possibility. I'm sure its pretty dirty inside there after 12 years of Wisconsin road conditions.
whiterover123
Off Topic
19
Oct 30, 2015 09:06 PM
ab4x4
Feb 18, 2015 02:22 PM
kimani01
17
Mar 1, 2012 07:35 AM
exquizit23
Jun 5, 2008 02:56 PM
Dervatl
Mar 26, 2008 01:40 PM
