Transmission Filter
Old Oct 29, 2015 | 08:09 PM
chubbs878's Avatar
Exclamation Transmission Filter
Oreillys Auto Parts ordered 2 transmission filters for me because there is a difference between them so I'm asking why 1 has the 1-inch extension built-in and the other does not, and which one do I need for the 2003?
The photo on AB shows shows the filter with the extended tube, pan gasket and 2 O-rings.
The 2 kits at Oreillys each had the pan gasket and only 1 large O-ring, but neither had the small ring that ABs kit shows. What gives?
Has anyone had transmission morning sickness where the truck doesn't like to shift from 3-4 until it has warmed a few seconds and will synthetic fluid fix that problem?
Old Oct 29, 2015 | 10:15 PM
chubbs878's Avatar
Bump.
Need info tonight
Old Oct 29, 2015 | 10:31 PM
lordmorpheus's Avatar
I went with the FK285 last time I changed it, I am 99% sure. My store is already closed, otherwise I would call and have someone check my account history for filters I've purchased. The kit I got had all of the seals and O-rings needed, even though they weren't shown in the picture.
Old Oct 29, 2015 | 10:50 PM
chubbs878's Avatar
On the 2000?
I'm wondering about that extension tube. AB shows the one with it. Google search has images of both versions. Guess I have to call AB in the AM
Old Oct 29, 2015 | 11:45 PM
Yes. On My 2000, and also a 2003 I worked on last summer. I just checked Rovers North, and they show the same filter for D1s, D2s, classics, and P38s.
Old Oct 30, 2015 | 12:16 AM
chubbs878's Avatar
Ya thanks I checked that out. Why does one kit cost $100 more than the other? Even the cheap one is over-priced compared to $15 at Oreillys
Old Oct 30, 2015 | 12:17 AM
chubbs878's Avatar
Did you use the filter with the 1-inch pick-up tube?? This is my main concern
Old Oct 30, 2015 | 12:42 PM
I checked my account history at work this morning. I used a FK279 on the 2002 D2 I worked on last year.
Old Oct 30, 2015 | 01:36 PM
chubbs878's Avatar
thanks for the info. I appreciate your time dude
Old Oct 30, 2015 | 06:58 PM
No worries. I remember I ordered in every option for several years so I could look at them to see the differences, and that was the number that best matched what the original looked like.
