Transmission fluid change
I understand that you cannot simply drain and refill the transmission fluid, that you'll only get about half (at most) out if you drain it.
What about the use of a vacuum extractor?
I'm coming up on the 60k service (at 58k+ now) and trying to get things sorted out to start the list.
Cheers!
Cheers!
the only way to get all the fluid out is to drain the torque converter. simply sucking the fluid out won't get it all. DiscoMike told me to drain and refill then drive it for a couple weeks. then drain it and change the filter and refill. the idea is to dilute and remove as much as you can.
Aint that the truth!!!!, mine did it automatically when the pipe failed, in traffic!!! emptied the box in seconds!!!!...............select D - push pedal and NUFFIN lol..........got nearly 9 litres back in mine I refilled it.
What? Oh, what you meant to say was 8.5 quarts!
collin Barrows
08-28-2011 07:13 AM
treant985
12-27-2010 02:51 PM
