Transmission fluid change
Old Jun 14, 2009 | 07:51 PM
Disco_Fever's Avatar
Default Transmission fluid change
I understand that you cannot simply drain and refill the transmission fluid, that you'll only get about half (at most) out if you drain it.
What about the use of a vacuum extractor?
I'm coming up on the 60k service (at 58k+ now) and trying to get things sorted out to start the list.
Cheers!
Old Jun 14, 2009 | 07:58 PM
d2luvr's Avatar
the only way to get all the fluid out is to drain the torque converter. simply sucking the fluid out won't get it all. DiscoMike told me to drain and refill then drive it for a couple weeks. then drain it and change the filter and refill. the idea is to dilute and remove as much as you can.
Old Jun 14, 2009 | 08:21 PM
Jupiter Rover's Avatar
Unplug the cooler line from the radiator. It will drain all the fluid out. Engine has to be on. Keep pouring fluid in until clear red fluid comes out of the cooler line.
Old Jun 14, 2009 | 08:24 PM
The only way to get 100% of it out is by a machine that hooks to your cooler lines and while the engine is running you exchange the old for the new.
As long as you chan ge the fluid often (every 30,000 miles) all you need to do is a drain in fill and then a filter every 60,000 miles.
Old Jun 15, 2009 | 03:01 AM
Urban Panzer's Avatar
Aint that the truth!!!!, mine did it automatically when the pipe failed, in traffic!!! emptied the box in seconds!!!!...............select D - push pedal and NUFFIN lol..........got nearly 9 litres back in mine I refilled it.
Old Jun 15, 2009 | 09:28 AM
What? Oh, what you meant to say was 8.5 quarts!
Old Jun 15, 2009 | 11:22 AM
Cant help it that you guys live in the past :P
Old Jun 15, 2009 | 11:25 AM
Lol!!
Old Jun 15, 2009 | 01:46 PM
tango123's Avatar
where is this cooler line located in the radiator.? I have a 97 disco series 1
Athana
Jun 8, 2019 10:23 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
dalfier
Jun 21, 2007 01:45 AM
jmang
Oct 17, 2006 06:58 PM
