transmission full drain and fill
I'm not sure about this, I was told that if you remove the transmission cooler lines and put the suction line in fresh trans fluid and the other in a 5 gallon pail you can change all the fluid in the trans. I was told change the filter and"o"ring with gasketfirst anyone ever done this?
Disco Fuego
02-22-2009 10:57 PM
