transmission full drain and fill
Old Apr 6, 2007 | 03:55 PM
gtagg's Avatar
Default transmission full drain and fill
I'm not sure about this, I was told that if you remove the transmission cooler lines and put the suction line in fresh trans fluid and the other in a 5 gallon pail you can change all the fluid in the trans. I was told change the filter and"o"ring with gasketfirst anyone ever done this?
Old Apr 6, 2007 | 09:25 PM
Default RE: transmission full drain and fill
Why tempt fate, your luck you would blow ATF all over the place when the pressure hits. It is not important to drain out every bit of fluid. If you do HD wheeling like I do then change the fluid every 15,000 to 20,000 miles.
Mike
mrossipir
May 15, 2013 09:53 PM
03discoman
Dec 24, 2009 07:29 PM
Disco Alan
Apr 21, 2009 06:22 PM
Disco Fuego
Feb 22, 2009 10:57 PM
llPANCHOll
Feb 7, 2009 10:13 PM
