transmission issue
Old Sep 16, 2007 | 10:55 AM
01discosteve's Avatar
Default transmission issue
When I start my disco and sometimes put it in gear without warming it up (in a hurry), it won't go into gear. Is this a typical torque converter problem like a domestic car?? Disco has 95,000 miles on it. don't know much about land rover trannies, would a torque converter change help?? Otherwise the tranny works fine.
Thanks,
Steve
Old Sep 16, 2007 | 11:29 AM
Default RE: transmission issue
What year is the truck, electrical or mechanical tranny, and how long has it been since you check the fluid level and or changed it?
Old Sep 16, 2007 | 01:38 PM
its an 01 disco 2. tranny serviced less than 5000 miles ago and fluid level is ok
Old Sep 16, 2007 | 01:50 PM
okdiscoguy's Avatar
are you sure the person that serviced it knew how to do it properly?
Old Sep 16, 2007 | 02:17 PM
yep. Why do you ask? service should include dropping the pan draining and flushing, and putting in new fluid and filter, correct??
Old Sep 16, 2007 | 03:01 PM
No, not that it is wrong, but on a D2, you only change the filter at 30K after that it is just a fluid change by draining the pan and refilling.
How many miles on the truck? Are you sure your fluid level is correct, have you crawled under and pulled the fill plug with the engine running?
Old Sep 16, 2007 | 05:44 PM
95000 miles. No I have not pulled the fill plug with the engine running, what would tat tell me??
Old Sep 16, 2007 | 05:49 PM
Pulling the fill plug is the only way you can check you tranny fluid level, you don't have a dip stick. So go check it to see if you are low on fluid.
Old Sep 16, 2007 | 09:38 PM
okdiscoguy's Avatar
That was why I asked. Jiffy Lube told me my tranny fluid was bad in my Caddy. ( it was 30 degrees out and not worth changing the oil myself)I asked them how they checked and the technician admitted he lied. He had no idea how to check the tranny... Just making sure it was done by someone you trust.
This is also the reason I stand out in the shop while anyone touches one of my cars.
Old Sep 16, 2007 | 10:51 PM
I understand fully. I am very mechanically enclined and usually do all of these things myself for that very reason. I will go check ASAP to find out and I will let you guys know. I appreciate the help
