Transmission just died! Grinding and wont engage
Here is a link to a thread a few months ago I started about a vibration in the transmissino.. This may refresh your memory of what issues I had
https://landroverforums.com/forum/di...g-still-55187/
Transfer case?
SO the trany won't grind unless I blew up gears I assume.. and I didn't do that
The Torgue converter won't grind??
Also I had that lound whirling noise in my truck while driving a few months ago as well.. here is a link to that
https://landroverforums.com/forum/di...ing-out-57715/
could This whirling noise and vibrations all have been coming from the transfer case?? Fluid leak out or it just went bad??
I have not noticed any fluids on the ground under truck other than oil..
Go - 3 MPH in Neutral. Or have a friend push you.
Try to move the transfer case shifter FORWARD to get you into low range.
Then see if it still grinds.
If it does. go to transfer case N on the small shifter and see if it grinds.
Then go back to "D" on the small transfer case shifter.
If the torque convertor was going bad - the truck would have juddered all the time off the line in 1st gear.
it is the opposite. if small tcase is in neutral it should cancel park and all else. it will roll in park if the tcase is in nuetral
