Transmission Mount
Transmission Mount
All,
how difficult is it to change out a transmission mount. I inspected my trans and drivelines due to a vibration at slow speeds and greater in lower gear. I found that the passenger transmount looks to be broken. I also am going to have front driveshaft rebuilt with greaseable ujoints. I looked in the rave cd but cannot find how to replace trans mounts. Any suggestion would be appreciated. Thank You
on
RE: Transmission Mount
On all vehicles, the l/f motor mount is the first to go cause iit takes all the engine torque lift.
Pretty common to see them fail, if your tranny mount is broken, I would replace all 3 and don't wait cause if all 3 fail, which can happen, thae engine will try and come right out of the engine compartment.
Butch
04-20-2005 09:07 PM
