Transmission oil cooler as engine oil cooler?
2004 Discovery II. Thinking of adding a OEM oil cooler for the engine, notice the OEM transmission cooler is identical and has a larger cooling surface. Is it a direct bolt on in front of the radiator and can it be used as an engine oil cooler?
That is a good question. I am looking at an aftermarket one, also looking at the gen - right hood louvers, mounting the oil cooler under one of the louvers, expelling the heat up. The engine bay heat will "vent" and the oil cooler will not get the "shock" of ice cold air passing over it. It will be the engine bay heat passing over the cooler leaving the bay. That's my theory anyways. Stg
bcolins
08-13-2013 06:41 PM
