Transmission Oil Temperature Light
Old Apr 16, 2009 | 08:55 PM
Robmcin's Avatar
Default Transmission Oil Temperature Light
OK, ran over to the other side of the river to let my son's dog out to go bathroom and when I left I got about 1/4 mile down the road and my tran oil temp light comes on... I go about mile to a parking lot to pull over and sit and wait like the manual says.. for about 10 minutes. Then I take off and real quick the light is back on. So I go to my daughter's house (about 1.5 miles and visit with them for a while, hop in light is out, 600 feet down the road light is back on.. then off, then on, then off... once I got out on the highway and up to 55, it went out and stayed out. I have the synth atf ordered to do the flush and fill.
I was not towing anything and it was only 60 degrees and I wasn't driving at high speeds.
Anybody?
Old Apr 16, 2009 | 09:06 PM
You have a bad temp sensor, a loose wire or loose wire harness.
Unplug the wire harness and clean it then wait and see.
Old Apr 16, 2009 | 10:35 PM
grussell's Avatar
I had a similar issue and I had water in the plug on top of the temp sensor on the transmission line just behind the radiator. I had washed the engine and water got into the plug. Cleaned it with electrical cleaner and light was gone.
Old Apr 17, 2009 | 11:17 AM
Or, you have an actual over heat issue, I would lean more towards this then a bas switch, which will act differently when failing.
PM me your tel number and lets talk.
Old Apr 17, 2009 | 01:06 PM
Robmcin's Avatar
Mike
PM coming. The light has not come back on today. I am planning on getting the tranny flushed and filled with RP as soon as the filter/kit gets here from Atlantic British.
Thanks
Rob
Old Apr 17, 2009 | 02:45 PM
Rob,
Do not do the flush or the Royal Purple till we talk, you can prematurely kill your tranny by doing that.
Old Apr 17, 2009 | 03:17 PM
Disco2Fever's Avatar
Rob, will you please post a recap of what Mike says?
That's sweet that these things have tranny temp lights.
cimca514
Aug 30, 2011 03:04 PM
Take THAT, Jeep!
Jun 18, 2011 05:58 PM
grussell
Feb 13, 2009 11:11 PM
kingster
Apr 11, 2007 06:27 PM
unco
Feb 1, 2007 11:19 AM
