Transmission STILL leaking
Ok, FMS, t-case, diff's, all resealed and not leaking a drop. But the transmission pan is killing me. It's a new pan, and new gasket. (old pan was damaged due to a front drive shaft failure) The thing is STILL leaking, from the drivers side rear. To be specific it's leaking and dripping on the nuts for the drivers side and drivers rear nut.
What's the trick here? Should I resort to RTV? Is the torque value on the rave cd wrong? should I check the mating surface on the trans to insure it's level?
If you tightened them to spec then go back and snug the leakers up a half turn a day until it stops.
It should only take one or two half turns to get it to stop, if not then there is something else going on with the gasket.
Rgr, will report back.
I suppose if it's out I'm going to be looking for a new transmission case, or just a transmission I suppose.
