transmission temp light on/off
Old Aug 28, 2021 | 12:29 PM
  #21
Extinct's Avatar
There are two sensors in that circuit, one in the transfer case and one in the transmission cooler. You can easily determine which one it is by unplugging the trans temp sensor, if the light goes off that is the problem, if not then it is the transfer case sensor. The connector is located under the radiator fan shroud at the top of the radiator on the passenger side, sensor is located in the bottom of the trans cooler on the passenger side.
errose2002
Feb 16, 2011 01:22 AM
Aussie Rabbit
Jan 21, 2009 11:52 PM
yuenie
Jul 30, 2008 08:37 AM
XtremePowerSports
Sep 22, 2007 08:27 PM
aladisco
Jun 20, 2006 11:37 AM
