Transmission temperature indicator light...
Old Nov 17, 2016 | 07:54 PM
Externet's Avatar
Question Transmission temperature indicator light...
Hi.
Does anyone know at what temperature the red warning lamp on the dash comes on ?
Just exploring if such warning could be used for engine coolant also/instead, with an additional sensor and some wiring surgery...
I can tweak a sensor to put out the signal at any proper value...
Also... If someone has witnessed it; when such overtemperature warning turns on, is there a chime with it ?
Old Nov 18, 2016 | 07:27 AM
Red5's Avatar
Don't know the actual temp that triggers the warning. Why not just install an aftermarket coolant temp gauge?
Old Nov 18, 2016 | 08:40 AM
Externet's Avatar
I already have a very good coolant thermometer, with its settable audible alarm.
I was thinking on other DII owners on the board that do not have such; to post a hopefully simple wiring modification that I could come up with, that would provide at least a decent coolant warning by using/repurposing the existing stock features.
Like the stock coolant thermometer overtemperature red light, but to warn earlier before damage is done.
Old Nov 18, 2016 | 09:07 AM
LR03NJ's Avatar
Im thinking that it should be wired separately. I dont want to mess with the discos electronics. I think it all goes to the computer and modifying it might affect other components when running diagnostics. Wiring alone is easy but our discos have a mind of their own. They will throw all kinds or code not in the book. Though I'm just guessing.
Kayode Oyenuga
May 3, 2015 03:21 PM
Robmcin
Apr 17, 2009 03:17 PM
grussell
Feb 13, 2009 11:11 PM
kingster
Apr 11, 2007 06:27 PM
unco
Feb 1, 2007 11:19 AM
