Transmission Won't Shift When Cold
Old Jan 26, 2009 | 04:47 PM
  #31
tomfraser's Avatar
Default RE: Transmission Won
I meant drain a little out because it is above the maximum? can that hurt terribly until saturday?
i'll probably do about 200 miles by then
Old Jan 26, 2009 | 04:50 PM
  #32
I know what you meant, and no, dont worry about it.
It wont hurt anything.
Old Jan 26, 2009 | 04:51 PM
  #33
tomfraser's Avatar
Thanks...
I really appreciate everyone's help
Old Jan 27, 2009 | 10:39 AM
  #34
tomfraser's Avatar
Shifted as normal this morning, and it was FREEZING
gonna drain and fill + change filter this weekend
Old Jan 27, 2009 | 11:02 AM
  #35
Consider adding a bottle of Lucas tranny additive on your next change to help free up all the internal parts for better shifting.
Old Jan 27, 2009 | 11:11 AM
  #36
tomfraser's Avatar
ORIGINAL: Disco Mike
will do... I meant to ask what brand you recomended earlier
Old Jan 27, 2009 | 11:35 AM
  #37
paul1454's Avatar
Do you guys change the filter everytime you do a fluid change?
Old Jan 27, 2009 | 01:33 PM
  #38
tomfraser's Avatar
no... it's supposed to be done in the 30k service and that is it
replacing the filter means dropping the sump which is a hard as the exhaust, and a giant bar are in the way.
Explain the history of service on your car and discomike or spike will recommend either changing it or letting it be
Old Jan 27, 2009 | 01:52 PM
  #39
Unless for some reason you have really burned fluid, then do a drain and refil and a few days later do a filter change and fluid change.
Old Jan 27, 2009 | 02:43 PM
  #40
ORIGINAL: paul1454
It was supposed to be done by the dealer at 30,000 miles.
If you do not know if it has ever been done then do it and then you will know that it has been done.
Changing a filter never hurts anything, not changing it will.
