Travel Tool Kit - Contents?
Old Jan 9, 2018 | 06:51 PM
  #21
Extinct's Avatar
Key spares that will keep Disco from running when it fails:
1. Crank pos sensor
2. Spare ignition coil
3. If you have not replaced all the coolant hoses, you need a repair kit at a minimum and a long ATF rated 5/16 line to replace the plastic lines LR thought were acceptable for coolant lines. Spare hoses are not a bad idea.
4. Inline thermostat mod makes it possible to remove the thermostat without losing all the coolant.
If you want to be extravagant, a MAF can be handy, maybe an xyz switch, an interior fuse box for the heater fan failure (or just bypass it before it fails).
Two guaranteed failures that are not serious but guaranteed to happen and low cost to fix - gasket for power steering pump and brake master cylinder seal kit (for the audi - starts leaking at the joint between reservoir and MC).
#1 most important thing - keep it full of coolant.
Good luck!
Old Jan 9, 2018 | 08:02 PM
  #22
Best4x4's Avatar
I forgot I also have a brand new CPS in my clear plastic tackle kit now as well. After Hurricane Harvey Abran got me up & going with a CPS, the last one I bought was from Auto Zone so I took the dead one back & got a free replacement & slapped it into my emergency kit.
The MAF I carry is removed from it’s housing making it easier to pack/store. I also have a spare plastic T, spark plug wires, ABS sensors, and a tire plug kit.
Old Jan 9, 2018 | 08:09 PM
  #23
Friday Night Disco's Avatar
I think the question needs to be asked slightly different. Let me explain...
Is the OP wanting to temp fix something so he/she can get home or to a garage?
Or, is the OP asking if I am 15 miles deep into an off-roading adventure, what should I have with me?
Obviously the tool kits and spare parts will differ.
Old Jan 9, 2018 | 08:36 PM
  #24
number9's Avatar
a fan clutch tool (the Gearwrench one specifically)
Normally not needed. One of your combo wrenches, if you don't scrimp on the sets, or a larger adj will fit clutch nut. Usually a whack with a hammer or mallet will loosen it when belt installed, if belt slips a rage under a pulley usually works unless corroded in place or gorilla installed. And easier procedure than using holding tool since we only have two hands/arms. Prevents skinned knuckles too. Save your bucks and the space in your box for needed tools.
Since you mentioned a U socket......In many/most applications wobble extensions work better and easier to use than universals. Unsure if for the specific app. and a offset adapter may work better on that particular rear head bolt.
Old Jan 10, 2018 | 07:13 AM
  #25
dgi 07's Avatar
AAA card
American Express credit card with concierge service. So you can tell the concierge where you are and your problem and they'll send someone to come get you.!!!
Old Jan 10, 2018 | 08:30 AM
  #26
tcr6v1's Avatar
Don't forget the big ol' 27mm lug socket
Old Jan 10, 2018 | 12:27 PM
  #27
LR03NJ's Avatar
For my winter travel kit. +AAA
Regular roof rack daily kit. Some hose extensions and clamps notbin picture yet.
Old Jan 10, 2018 | 12:32 PM
  #28
attworth's Avatar
Wow. Those are awesome. What’s in the small cans in your winter kit?
Old Jan 10, 2018 | 01:27 PM
  #29
LR03NJ's Avatar
Those can be any canned food you want.
Old Jan 10, 2018 | 01:33 PM
  #30
attworth's Avatar
Oh, I see it now. They seemed smaller than a can of food.
Thanks for sharing, those are some great kits.
