Tres amigo's
Old Aug 21, 2013 | 03:52 PM
Celto 4's Avatar
Default Tres amigo's
Hi everyone guess I got to address this problem am aware how and why... Where is the best place to get the unit for the ABS module?thanks
Old Aug 21, 2013 | 04:12 PM
ralphobell's Avatar
You want to replace the entire module? There are other things you can do to fix it.
Shuttle Valve Switch, etc.
Read this first: https://landroverforums.com/forum/di...s-fault-26847/
Old Aug 21, 2013 | 06:30 PM
Celto 4's Avatar
No just want to do the valve if necessary and the bad wiring
Old Aug 21, 2013 | 06:33 PM
Celto 4's Avatar
Or your suggestions I haven't done one but watched one being fixed I was wondering of there was a diff in parts?
Old Aug 21, 2013 | 09:08 PM
ebg18t's Avatar
I used that fix and worked perfect.
Old Aug 21, 2013 | 11:30 PM
ralphobell's Avatar
For the Shuttle Valve I would recommend FalconWorks and also get the shuttle valve seals. It is a bit more in cost but well worth it.
ABS shuttle valve code solution; brake fluid leaks
For the wiring, any standard 2 prong trailer connector will work. Can usually be found in any automotive store.
If you don't already have an ABS tester you have a couple of choices.
1.)
Amazon.com: Autel AL619 OBDII/CAN Scan Tool: Automotive Amazon.com: Autel AL619 OBDII/CAN Scan Tool: Automotive
or
2.) http://www.rswsolutions.com/index.ph...d=56&Itemid=55
I have done the above fix and currently have both of the scanners. After doing the install I would recommend going ahead and flushing the entire brake system with new fluid. Follow the RAVE on bleeding steps and order.
Old Aug 22, 2013 | 08:48 AM
You never expect the Josh's A and B repair will always fix the 3 Amigo's, there are at least 16 different reasons for the lights to come on and until you get the codes actually read you are just guessing and or wasting your time.
Old Aug 22, 2013 | 12:10 PM
Celto 4's Avatar
Thanks ill get them!
Old Aug 22, 2013 | 12:36 PM
Celto 4's Avatar
I got 01 mass air flow sensor? And 1452? Could drive shaft vibration be doing it?
Old Aug 22, 2013 | 12:53 PM
Explain your last message, what do you mean you have a MAF and as far as I have checked there is no 1452 for your truck.
