And tricks to installing the long side drip rail trim?
Old Apr 6, 2022 | 10:15 PM
austinlandroverbill's Avatar
Default And tricks to installing the long side drip rail trim?
I have come into possession of perfect condition left and right drip rail trim pieces.
Given how rare (right?) and fragile these unobtanium trim pieces are. I want tp make sure I get them installed without incident, so advice on how to proceed would be appreciated.
Clip in from top to bottom or bottom to top?
Start at front and work back toward the rear curve or start at the rear curve and work forward?
Old Apr 7, 2022 | 05:20 AM
brivalen's Avatar
Use a helper and get the front and back tucked in first, then you can rotate into position. I let mine sit in the sun for a bit just to make them a bit more flexable.
BTW - at least about 6 month ago you could still get these brand new at the dealer - not cheap but under $200.
Old Apr 8, 2022 | 09:33 AM
I paid $5 each from the junkyard for 2 perfect pieces, one for each side. I am giddy with the anticipation of installing them.
Waiting for a super hot day and letting them soften in the sun is a great idea. I think I will also use silicon spray to get them to slide on easier -- good idea?
And where are yinz from in the 'burgh?
Old Apr 8, 2022 | 01:58 PM
Extinct's Avatar
Roll them on from bottom to top - the rear corner is the hardest, use a heat gun to get it flexible so you dont' break it.
Old Apr 10, 2022 | 12:29 PM
nashvegas's Avatar
The ** single biggest ** tip I have is mentioned above... do this on a warm day, in direct sun. The plastic easily cracks at low temps when removing/installing (even new ones... ). And I start by putting the rear corner on (again... warm plastic!) then slowly working my way to front. If you haven't removed the A pillar and front corner molding, you can tuck the front edge in behind the front corner molding too...
Old Apr 11, 2022 | 07:35 AM
Warming the plastic seems to be the consistent advice. I'll let you know how it goes
heliochrome85
Aug 29, 2022 12:27 PM
austinlandroverbill
May 2, 2022 01:32 PM
austinlandroverbill
Mar 12, 2022 11:32 AM
zuke
Aug 22, 2018 03:47 PM
