Tricky Dick - Cooling System V4
Old 04-22-2018 | 01:19 PM
Friday Night Disco's Avatar
Default Tricky Dick - Cooling System V4
Ok - So some of you might remember about a week ago that my lower hose blew off my t-stat and I was stranded about 8 miles from my house. After a $56 AAA membership, I got Tricky Dick back home.
Since then, I have ordered a new lower hose and a 180 degree t-stat from Lucky8
To avoid a hose blowing off again, I have picked up some worm gear hose clamps to replace all the OEM clamps on every hose with the exception of the hose that "used" to go to the throttle body heater.
Today, I removed all the hoses and flushed they system. Tomorrow or later this week, after everything dries out, I plan to reassemble and start the bleeding process.
Old 04-22-2018 | 09:30 PM
Saturnine's Avatar
Nice work!
I guess what bothers me is that bleeding the system shouldn't be a process but rather a simple task.. Bleh!
Old 04-23-2018 | 02:14 PM
Everything is put back together and so far no leaks
Trying my new bleeding process as I thought about how the heater core is positioned...
Old 04-23-2018 | 06:17 PM
Saturnine's Avatar
I would think the higher the front of the truck the better, no? Not really tilted to the side?
Old 04-23-2018 | 06:30 PM
the inlet and return for the heater core come out on the passenger side. There is about two inches from the base of the top heater core hose and the top of the heater core itself. Thought is that the tilt in the passenger side will allow any air in that two inch gap to escape.
i don’t have a bleeder valve any more so giving this a shot to see what happens
Old 04-23-2018 | 08:57 PM
Saturnine's Avatar
So you are just using the expansion tank to bleed then?
Old 04-23-2018 | 09:17 PM
roger that
Old 04-24-2018 | 08:29 AM
Drove the truck to work
temp never got past 186. The bleeding process went quickly and I think I might be onto something by jacking up the passenger side
Old 08-26-2018 | 05:11 PM
Is this a common O ring or a special part from Land Rover or a rubber gasket on the end of the pipe?
Old 08-26-2018 | 05:24 PM
Saturnine's Avatar
Probably something you can get at a hardware store
Quick Reply: Tricky Dick - Cooling System V4
