Tricky Dick - Metal Tee
Old 01-06-2018, 05:01 PM
Friday Night Disco's Avatar
Default Tricky Dick - Metal Tee
I got the non bleeder tee for $24 from here:
http://www.jagsthatrun.com/Pages/Par...rass-Tees.html
Seller was quick to ship 3 days from order to arrival.
Fits like a glove but, I would recommend replacing the hose clamps with the ones I used.
The following 2 users liked this post by Friday Night Disco:
Best4x4 (01-10-2018), Lisa Bunch (01-06-2018)
Old 01-06-2018, 05:39 PM
number9's Avatar
How about a link to the clamps.
Old 01-06-2018, 07:56 PM
mr. choodles's Avatar
Curious, when you installed the tee, did you spin any coolant? I can't spill any liquids when I work on the car where I live, so anything that requires liquid clean up has to be done elsewhere...
Old 01-06-2018, 08:15 PM
Clamps were from auto parts store, I dremelled the extra length off
Yes, not much and an old towel under the truck would help, you could clamp all three hoses before removing the tee and spill a slight amount.
Old 01-06-2018, 08:18 PM
Darn it. Need a place with a garage where I can wrench, spill, and clean up. Even a small amount of liquid will generate a ton of inquiries from my concerned neighbors.
Old 01-06-2018, 08:20 PM
This took about 10 minutes, do it at a grocery store parking lot
Old 01-06-2018, 08:29 PM
dtmbinb's Avatar
Do you still have a factory style thermostat or inline? How are you bleeding without the bleed screw?
Old 01-06-2018, 08:42 PM
Factory t-statFor bleeding, I raise the tank and let the truck run for 30 minuets with a few 3k rev holds.Stone cold repeat process two or three more times while topping the raised tank off.
Old 01-06-2018, 08:48 PM
OverRover's Avatar
The Tee with the bleed screw will be available (spoke w JTR on 12/28) if you can wait until the end of the month. V8 Chevrolet TPI & TBI, Radiator Hose Tees, Stealth Conversions
Old 01-06-2018, 08:49 PM
shanechevelle's Avatar
Find an auto parts store. People always pop the hoods at auto stores.
Quick Reply: Tricky Dick - Metal Tee
