Trim Adhesive Recommendation
Old Apr 28, 2019 | 05:55 PM
cvhyatt's Avatar
Default Trim Adhesive Recommendation
I have a number of trim pieces that are partially coming off due to broken plastic connectors. I am thinking I can just squeeze some heavy duty adhesive behind each piece to hold it in place. Any recommendations on what you might have used to do something similar?
Old Apr 28, 2019 | 06:57 PM
Discorama's Avatar
Aquaseal. I glued the seat leather, the warping dashboard and a plastic hook of the moonroof screen and all still holds without the slightest signs of failure after one year. The best glue you can get for almost everything, not only for the Rover.
Old Apr 28, 2019 | 06:59 PM
cvhyatt's Avatar
Thanks. You think this will hold up for exterior trim? Pretty harsh heat here in florida.
Old Apr 28, 2019 | 08:31 PM
Discorama's Avatar
Sure. Dashboards here in CA get even a lot hotter. And it's waterproof.
Old May 22, 2019 | 12:05 AM
Discorama's Avatar
Here is what I ordered again today. Double pack since I use it a lot.
https://www.ebay.com/itm/Gear-Aid-Aq...k/262899337390
It's urethane glue, there might be other brands available.
Old May 22, 2019 | 11:24 AM
FlyingZebra34's Avatar
What trim adhesive do you guys use for the fenders that are glued on?
bcolins
Apr 16, 2019 09:42 PM
Gator996
LR4
Jun 16, 2018 09:37 PM
DonRW2007
Dec 8, 2013 12:14 PM
SuperiorCarCare
Detailing
Oct 22, 2013 08:25 AM
noahsfortune
Jun 20, 2010 03:59 PM
