Truetrac part numbers?
Old May 13, 2013 | 09:58 PM
fern540's Avatar
Question Truetrac part numbers?
Ok i recently purchased front and rear truetracs, i am about to install them with the help of a mechanic buddy and looking on the diffs for a part number i see 912A693 on one and 912A694 on the other. I can't seem to find these part numbers online to figure out which one is front or rear! Hopefully i got the right ones shipped! The only other numbers i see are TT70P10284 23m11 and TT70P1028 24k11. They are being installed into an 01 D2 SE7. Anyone have the answer?
Old May 14, 2013 | 08:02 AM
ZGPhoto's Avatar
Why is there a front and rear? I would imagine the diffs would be the same.
Either way, here are the part numbers:
Front: TT 912A407
Rear: TT 912A383
Old May 14, 2013 | 08:44 AM
jafir's Avatar
Front: TT 912A407
Rear: TT 912A383
In a truetrac the gears spin opposite directions for front and rear.
Flipping Truetrac Gears
Old May 14, 2013 | 08:46 AM
ZGPhoto's Avatar
Interesting, but what about driving in reverse?
Old May 14, 2013 | 08:52 AM
When you install the T.T.'s, make sure to only use convential 85/140 oil, no synthetic because it will slow down the T.T. reaction time. Also, make when wheeling that you are always locked up and be very careful to run all 4 tires at the same pressure, I speak from experience with them, love them but you do need to learn a few tricks to get the most out of them.
Old May 14, 2013 | 09:23 AM
jafir's Avatar
I think they will still work backwards, but maybe not as well. I don't think ashcroft has two different parts for their version, since their version supposedly works a little better anyway, with twice as many gears.
Old May 30, 2013 | 01:50 PM
Stenninski's Avatar
4th Gear
Hi did you ever solve this problem? I have the same problem I have the 912a694 and need to know whether its a front or rear
Old May 30, 2013 | 03:22 PM
jafir's Avatar
You can tell front from rear by looking at it:
If not the right one you can change it.
Old May 30, 2013 | 03:57 PM
Stenninski's Avatar
4th Gear
Mine is built into the diff casing was just trying to identify it by that number to save stripping it down
Old May 30, 2013 | 08:08 PM
Fivespddisco's Avatar
Originally Posted by fern540
Ok i recently purchased front and rear truetracs, i am about to install them with the help of a mechanic buddy and looking on the diffs for a part number i see 912A693 on one and 912A694 Anyone have the answer?
912A694 is the front
912A693 is the rear
