Trying to figure out what (if anything) I broke while messing with the ABS
Old May 12, 2024 | 05:07 PM
disco_nap's Avatar
Default Trying to figure out what (if anything) I broke while messing with the ABS
I replaced my shuttle valve switch today, to get better access, I removed the brake lines from their brackets up against the firewall. I don't know if this hard plastic tube was attached to something that I broke off, or if it's supposed to be like that (e.g. bleeding off something or other). I can't find anything in the RAVE, probably because I have no idea what to search for.
Here's are a couple pics, the tube in context and a close up:
Old May 12, 2024 | 05:54 PM
jastutte's Avatar
i believe that is a differential breather.
Old May 12, 2024 | 06:15 PM
mln01's Avatar
That is a vent line for the transmission, the front differential, or the transfer case. It is supposed to be open like that.
You say you replaced the shuttle valves switches. Did you also do the Option B bypass?
Old May 12, 2024 | 06:34 PM
disco_nap's Avatar
Funny you ask. Since the codes and lights came back, I’m currently at Home Depot shopping for butt connectors and silicone 😀
Old May 12, 2024 | 07:03 PM
mln01's Avatar
There are many ways to do Option B. Butt connectors wouldn't be my first choice, but okay. But what's the silicone for?
Old May 12, 2024 | 07:48 PM
disco_nap's Avatar
In case I give up on the butt connectors and solder instead.
Old May 12, 2024 | 08:34 PM
disco_nap's Avatar
I noticed some bare copper around the old switch's solenoids. I might also put a dab on preventively.
Old May 12, 2024 | 08:40 PM
mln01's Avatar
What the heck is the big white circular thing with the orange rectangle in the middle?
Old May 12, 2024 | 09:01 PM
disco_nap's Avatar
That's one of the two switches. And I guess the orange thingy isn't a solenoid... Actuator pad maybe? I need an EE to step in and correct terminology 🤣
Old May 13, 2024 | 06:14 PM
mln01's Avatar
Ah. The perspective of the first photo made it look like the switch was a lot bigger than it actually is.
I've never removed the individual switches from the black "frame" in which they are mounted. And the orange thingy is just the material that covers (and protects?) the connections within the switch assembly. You can see it was likely applied as a liquid that then cured to a solid state.
But I'm confused. In your first post in this thread you wrote "I replaced my shuttle valve switch today ...". Did you replace it with another used SVS assembly?
I've seen and seen reported recently more cases of the insulation on the wiring inside the switch assembly having deteriorated or disintegrated entirely. Given the way the wiring in the SVS assembly is routed and protected, it's not clear to me it's actually needed. That said, a guy here whom I helped a few months ago with his Option B fix elected to buy a new SVS assembly.
