Trying to remove rear diff pinion flange
Old Apr 14, 2014 | 07:16 PM
ralphobell's Avatar
You can purchase the tool here for.....wait....wait.....hold on to your skirt.....$320
OTC Tools LRT-51-008 Pinion Flange Remover
Old Apr 14, 2014 | 08:41 PM
ralphobell's Avatar
Take a look at this post on Discoweb.
2000 DII pinion seal - DiscoWeb Message Boards
Old Apr 14, 2014 | 08:52 PM
jalodge's Avatar
Originally Posted by OffroadFrance
PITA
Soak the pin in acetone/cellulose thinners overnight to release any Loctite engineering adhesive they've used it breaks down the polymers.
What diameter is the pin size that sticks out of the flange where the central thread is located?
I don't have an exact measurment but probably almost 2".
Old Apr 15, 2014 | 02:29 PM
OffroadFrance's Avatar
GULP.................................$320 bucks eerrrr that's £200.................I think a bit of home made ingenuity is called for instead. 3" diameter steel pipe socket, some 3/8" plate and a 10mm high tensile 8.8 studding and matching nuts and washers. It's got to be worth a try and a lot cheaper.
What about hiring it from an LR shop?
Old Apr 15, 2014 | 03:01 PM
ralphobell's Avatar
There are some cheaper places to get them...but not by much. Here is how PTSchram on Discoweb says he removes them and he has removed plenty.
"The hole is 8*1.25.
I use my hub nut socket, a bolt and a washer. They have always popped right off for me, but some folks have a horrible time with them"
Maybe using an impact wrench as well....not sure.
bosshogt
Aug 4, 2011 12:49 AM
errose2002
Apr 19, 2011 07:51 PM
Danny Lee 97 Disco
Jan 27, 2011 09:32 PM
NiteTrain
Sep 10, 2010 08:48 PM
ek5usmc
Dec 5, 2008 08:31 PM
