Trying to unbolt Driveplate from Torque Converter
Old 08-24-2011, 08:33 PM
ruffram's Avatar
Hopefully Con Rods are ok but they could be shot. I just rebuilt a Jeep 4.7 motor with bad rod bearings and had to replace 2 rods. I just hope crank can be ground. British Atlantic shows oversized bearings 2 sizes, I just hope damage isn't too bad and I don't have to get a new crank. If that's the case I will just try to find a short block assembly from a salvage yard.
Old 08-24-2011, 08:38 PM
disc oh no's Avatar
roverlandparts.com has them for $300 I think. If you don't have another source for them. Also, con-rods are $75 I think through them, not sure of shipping costs though.
Old 08-24-2011, 09:40 PM
ruffram's Avatar
Wow that's not too bad at all. Thanks man I didn't realize there was a place that had reasonable prices for them
Old 08-24-2011, 09:54 PM
When you complete your work, the new power will overwhelm the equally old and worn props shafts
Old 08-24-2011, 09:57 PM
ruffram's Avatar
I plan to check out the U joints and rebuild the front shaft as it doesn't look like its been done yet. The rotoflex rear joint doesn't look too worn but I'll keep an eye on it, and eventually convert it to U joint as well
Old 08-24-2011, 10:16 PM
lordmorpheus's Avatar
...but the new power will not overwhelm you (unless you are used to driving 180HP 4k+Lb vehicles)
sidenote: Today I picked up my last paycheck from the auto repair shop I used to work at and noticed they had an 03 Disco in the lot. Even though I despise the owner and bear nothing but ill will towards him, I told him about the recommendation to rebuild the front shaft, and reasons why, just to prevent another Disco calamity.
Old 08-24-2011, 10:28 PM
disc oh no's Avatar
sidenote: Today I picked up my last paycheck from the auto repair shop I used to work at and noticed they had an 03 Disco in the lot. Even though I despise the owner and bear nothing but ill will towards him, I told him about the recommendation to rebuild the front shaft, and reasons why, just to prevent another Disco calamity.[/QUOTE]
You're a good man!
Old 08-24-2011, 10:32 PM
disc oh no's Avatar
That's used prices, just to be clear. All their parts are used unless otherwise noted. I have ordered stuff from them though and they are pretty good. They wont sell anything that's got any serious wear or anything like that. I think they will give you a credit if you end up sending anything back but, you have to send it back within 30 days or they will not refund you even in credit. Just a heads up. Make sure you NEED what you order.
Old 08-24-2011, 10:39 PM
ruffram's Avatar
That sounds fine with me. Used parts in good shape don't bother me a bit, these trucks are so rare its hard to find reasonable price especially from a place that checks them out and stands behind what they sell.
Old 08-24-2011, 10:44 PM
0304Disco's Avatar
I haven't had much luck any time I called Roverland for a part I needed. When I rebuilt my 4.6 two months back I
bought just about every internal engine part from Turner
Engineering in the UK including
a block for much less then I
could have purchase it for in the US. I had my crank turned .10
under to go with the first size of oversized bearings.
Quick Reply: Trying to unbolt Driveplate from Torque Converter
