Tune Up
Old Jan 13, 2017 | 11:31 PM
AZRover's Avatar
Default Tune Up
Plugs, wires, air filter.
What else?
Old Jan 14, 2017 | 12:31 AM
LR03NJ's Avatar
What else?
Coils and plenum?
Old Jan 14, 2017 | 02:12 AM
Luckyjayb's Avatar
What else?
Mass air flow sensor, vicious fan clutch, and valve cover gaskets
Old Jan 14, 2017 | 07:14 AM
number9's Avatar
Tires and brakes to round it out?
Old Jan 14, 2017 | 11:13 AM
OffroadFrance's Avatar
If it ain't broke don't fix it, if it's sluggish try the 'Italian tune up', give it 'the beans' on the autoroute for half an hour, it's a make or break cure.
Old Jan 14, 2017 | 11:33 AM
Best4x4's Avatar
Check your fan belt, plugs, wires, clean throttle body, IAC, replace air filter, inspect flex hose to fender for holes, and change the oil & filter.
Old Jan 14, 2017 | 02:32 PM
AZRover's Avatar
What's the Italian tune up?
Old Jan 14, 2017 | 03:39 PM
Jeff Blake's Avatar
OffroadFrance has some wise words. My "tune up" ended up being a complete engine rebuild. Ha! Where do you stop...
Old Jan 14, 2017 | 04:10 PM
mln01's Avatar
These guys are jerking you around.
Starting with plugs, wires and an air filter is just fine. But even before that, are there symptoms or codes you are intending to address with a tuneup?
When I learned to turn a wrench a tuneup, as I recall, meant new plugs (which in those days, 40+ years ago, had a much shorter service life), checking the distributor points (which no longer exist in modern cars), adjusting the idle advance timing with a dwell tach (which I still own just in case I ever get that '49 to '53 Chevy pickup I always wanted) and making all the requisite carburetor adjustments.
Today a tuneup is much more simple. Do not overcomplicate it.
Old Jan 14, 2017 | 05:07 PM
The 'Italian tune up' is you give the truck or car a 'b@lls out' hard run using max throttle for 15 to 30 minutes and then see whether it's improved, as already said, it's a make or break scenario.
