tune up question
Old Aug 3, 2008 | 10:47 AM
JBEGIN's Avatar
Default tune up question
I would like to do a tune-up on my Discovery II, and noticed that the Distributor location doesnt leave much room to work on the wires. Is it necessary to remove the Intake manifold to replace the plug wires? And what would be a good manufacturer to use for the plugs and wires? Any advice would help?
Old Aug 3, 2008 | 10:53 AM
Default RE: tune up question
Yes you must remove the intake manifold. And you MUST use Mangnecor plug wires. Anything else and you will be doing this job again in a month.
Old Aug 3, 2008 | 10:55 AM
Its a 5 hr job. If you have small hands you can feed the wires through.
Old Aug 3, 2008 | 11:05 AM
JBEGIN's Avatar
I do have small hands, however im not very mechanical, so should i have someone do this? and the plug wires dont say magnecor, they are some red wires i forgot who makes em.
Old Aug 3, 2008 | 11:19 AM
If you want to peace of mind then have someone else do it. A tune up isint complicated. But on a DII it does take paitence.
Old Aug 3, 2008 | 11:20 AM
www.roverconnection.com
www.atlanticbritish.com
Both have tune up kits with the Magnecor wires.
Old Aug 3, 2008 | 01:22 PM
If you have small hands, I can walk you thru this without removing the intake manifold.
How many miles on the truck and what years is it?
Old Aug 3, 2008 | 04:48 PM
JBEGIN's Avatar
Ok MIke that would be great! Year is 99, Mileage 130,000... I'm all about purchasing these Magnecor wires, which plugs should I get?
RoverConnection.com has OEM plugs, are they better than Bosch which makes my engine?
Old Aug 3, 2008 | 04:51 PM
Bosch doesnt make the engine, they make the engine management system.
Old Aug 3, 2008 | 05:01 PM
JBEGIN's Avatar
Ok I stand corrected, But what plugs? Does it make a difference if I get Land rover plugs or if i go with Bosch?
