Turn signal issue...weird...
So, um, my turn signals dislike extreme cold.
We've had below freezing temps these past three days and every single day, my signals didn't work until it warmed up later in the morning.
For two days they wouldn't turn on at all until the ice melted off the car around 10 or 11. Then, they'd turn on but it would take 5-10 seconds to kick in. By noon they were normal. Yesterday they'd go on after the 5-10 second delay right away in the morning. By lunch, completely fine.
This morning the temp was in the 40s and they worked just fine in the driveway.
Is my Disco just weird and stubborn or is something about to go wrong?
Thanks!
Thanks!
RE: Turn signal issue...weird...
Well, I also have an 03' and mine does the exact same thing.Last week it was about 17 out during the day and even colder at nigth and I had the same symptons as you.The weatherwarmed up a day later and it was just fine. It has done this twice now this year winter.I am guessing a loose connection and the extremecold is causing wherever it maybe to get even more play in it?Gotta love LR's!
Welcome back Annie. We haven't heard much from you lately, at least not that I've noticed. From what I have read what you are describing is pretty common in D2s. Weird part is that D1s use the same turn signal switch and don't have the problem. It's something in the wiring of D2s. Too much electronic crap I guess.
2004 Discovery 70k miles just developed same issue. Dont think its the ambient tempreature however. I'm in southern California and the delay will happen on an 80 degree afternoon. It seems to be more of a "cold start" issue- on the switch itself. For example, I could have driven for hours without using the turn signal, then suddenly go to use it and nada- for maybe 5-10 seconds- then presto it works. And once I get through the first delay it semms to have "warmed up" and then works fine everytime that same drive. Then, when I park it for a long period, the process repeats on the next drive.
What a crummy switch! Is buying a $150 complete new turn signal/light switch the only fix??
ok just a thought, when I took my switch apart there was a lot of grease in the switch, not sure if this grease would hamper the electronics (it is there to ease the turn signal mechanism inside the switch) but it may be a little too much I tried cleaning the contacts really well, not sure if this will help your problems
You need a new turn signal switch/stalk. They are not to expensive. You will probably end up with the same problem on your wiper stalk. I had to replace both at 60k. I went with a new turn signal for around $100 and used wiper for $30. The new wiper is $350. I took both out and cleaned them and it did not help.
