Turning circle and the unthinkable.
Well this week I'm going to do the unthinkable. I've lived with the D2 abysmal steering lock for 11 years now and it originally had 18" wheels and now has 19" RRS wheels for the past 7 years. Although the overall rolling diameter is exactly the same as is the tire width it shouldn't change the dynamics I hope, (famous last words). So, at present I have 29mm steering lock stops and I'll see whether there is sufficient clearance between the tire and the sway bar on full lock. If there is sufficient clearance I'll remove the stops and put them in the lathe and turn them down a millimetre at a time until I have just sufficient clearance between tire and sway bar allowing for deflections. Yep, you can buy new stops but at a price £20+ per pair plus packing washers. So I'll try the unthinkable and spin off a few millimeters in the lathe. From what I've calculated every millimeter less stop is worth 9-10" less turning circle .......... eeerrrr ............ hope my math is correct
I've always hated having to back up to maneuver into a tight place. Was hard to get used to after 300K + miles in a jeep. I've been driving it like that for almost 8 years and still misjudge my turns sometimes.
Let me know what you end up removing when you do that. This truck has 18's and with stock width tires. My other truck will have 16's with tall skinny tires and I'll have to take it off a little at a time like you are doing.
Just as an aside guys and for future reference, NEVER hold the steering forced against full lock as the steering box bypass valve isn't designed for that kind of punishment and will give up pretty quickly and it'll cost you big time for a new box and fitting. It's not an easy or pleasant job to do yourself
This recommendation is in the owners handbook or in the RAVE manual.
I'll post the results of my steering stop mods when done but it'll be next week now as I'm on with another project at the moment (I'm reigned in and under instructions from her indoors who must be obeyed ) .
Follow up.
I checked out the clearance between the tire and the sway bar and radius arms both sides and there is only 30-40mm which isn't enough to bother with in reducing the steering stops especially as this check was stationary with no dynamic wheel movement. This is running 255x50xR19 stock RRS wheels/tires on a stock D2 which would be exactly the same for the 255x55xR18 on standard stock wheels. As the Continental tires cost about £220 each ($375) it's not worth trashing the tires or the suspension for the additional turning circle, if any.
Hey-ho, another job I don't have to do
Did you look to see if yours have the same length steering stops on the 03 as on the 04's? They make a long one and a short one and I have read that some have installed the short one for tighter radius but, if the shorter one makes the tires rub with stock width rims/tires, I don't see how anybody could use it?
