TWO amigos!? Dos Equis?
Old 07-01-2015, 02:33 PM
Broken08's Avatar
Default TWO amigos!? Dos Equis?
The PO did the wiring bypass thing on the ABS module. Now I'm getting a constant 2 of the three amigos. The TC and HDC but NOT the ABS.
Does this lead me to a more likely solution or place to look or do I really just need to give in and buy a fancy code scanner?
Old 07-01-2015, 05:01 PM
disc oh no's Avatar
Just by chance, is the bulb in the ABS light burned out?
Old 07-01-2015, 05:32 PM
dusty1's Avatar
Need a scanner. Let me see where amigo is. If it has done its duty at its current stop , we can send it your way if you want.
Lemmeknow
Old 07-02-2015, 12:04 AM
Broken08's Avatar
I'm all for tool sharing, I'm in.
The abs bulb works :-)
Or is there a fairly cheap scanner I can just buy that will do more than just the amigos?
Old 07-02-2015, 05:56 AM
drowssap's Avatar
icarsoft will do ABS, SLS as well as standard OBDII for $140, I think the amigo reader sells for $100 by its self.
Old 07-02-2015, 05:58 AM
disc oh no's Avatar
So one Amigo has gone rogue.
Old 07-02-2015, 07:04 AM
dusty1's Avatar
I think it's in Florida ... I will see if it is ready to leave
Old 07-02-2015, 07:20 AM
The phantom of the Amigos
IMO only route left is to scan for the codes otherwise it's just guessing. The only possibility I can think of is either the SLABS ECU has gone AWOL or an inline electrical connection is defective.
Old 07-02-2015, 08:35 AM
dusty1's Avatar
the little amigo is like 125-135 iirc
140 for that icar thing is much better deal
Old 07-03-2015, 12:13 PM
OK Dusty, joke over, give him back his third Amigo or you'll have to sit on the naughty step
Quick Reply: TWO amigos!? Dos Equis?
