Two Engine Removal Questions- Help
Old Mar 10, 2017 | 03:37 PM
twin6's Avatar
Default Two Engine Removal Questions- Help
So yes I am reading the RAVE.
I am doing a 4.0 to 4.6L engine swap since the 4.6L is dead and I know that I want to keep my 4.6L ECM with the 4.0L engine.
The RAVE has me doing two things that I am not sure I need to do in my circumstance.
Question #1: Step 24 of 12.41.01.99. Since I am not swapping out the ECM do I need to remove the engine harness from the truck since I want the 4.6L harness to stay with the original truck.
Question #2: Step 29 of 12.41.01.99. Do I really have to remove the whole front pipe or can I just remove the exhaust manifolds from both the heads and the front pipe?
Old Mar 10, 2017 | 03:45 PM
Luckyjayb's Avatar
I can't answer question one but question 2 you should be able to but since you have to remove the crossmember, why not just unbolt the manifold, loosen the nuts connected to the cat and remove the 2 bolts holding the cat to the muffler. It's not that hard and you can just unclip your o2 sensors BC you don't want coolant and all the other grime getting on them
Old Mar 10, 2017 | 04:03 PM
twin6's Avatar
Why do I need to remove crossmember? To drop transmission?
Old Mar 10, 2017 | 04:13 PM
Luckyjayb's Avatar
easier to wiggle and adjust if you need to. I'm only talking about the front one though
Old Mar 10, 2017 | 04:14 PM
Luckyjayb's Avatar
And your heads are where your factory lifting eyes are bolted to
ljdiscovery
May 28, 2014 09:46 PM
MilehighLR3
Sep 22, 2010 10:26 AM
AAP
Apr 1, 2010 10:23 AM
AAP
Mar 12, 2010 10:09 PM
tornado_735
Mar 3, 2009 02:34 PM
