two "future" problems?
hey everyone!
i have two things that are begining to happen...
1.) my driver's side window is making a clunky sound when i roll it down...i figure it is getting real close to coming off the track. is there any preventative maintainence i can do to make sure it doesn't come off the track?
2.) my GF was driving the truck and told me the a/c was not blowing out of the vents. she picked me up at the airport, and we were driving with the a/c on, but there was no air coming out of the vents. it was like it was shut off, even tho the display was on...while we were waiting at a light (in 115+ heat), it just came on. it was so weird, and now the a/c is blowing just fine, i dont get it. has this ever happened before to anyone else?
thanks guys!
thanks guys!
on
1.) The plastic window roller may have killed itself and you will need to open the door trim, remove the regulator/motor assembly and replace the wheel. THere are many ways to replace the wheel.
http://www.jewellamberoil.com/sales/...roducts_id=185
http://www.aulro.com/afvb/projects-t...ir-waynep.html
2.) Wait to see if it happens again.. I haven't experienced that .....
but its working fine now, and has been for almost a week.
the problem hasnt happened again, hope it doesnt.
![Cool](https://landroverforums.com/forum/images/smilies/kKt1IJ6.png)
Sounds to me like your HVAC fan is on its way out. That's the only thing that would cause it not to come out of the vents at all. If the A/C compressor was bad or the system needs recharged you would at least get air movement through the vents.
Get under the dash and make sure the connections are clean and tight on the blower.
Street Wolf
15
11-05-2013 12:34 AM
