Two things I want to tackle today...got some questions!
I've got a power steering leak I have to take care of. I've identified the source of the leak but what I can't find locally is the fluid specified in the manual. What is everyone using and can it be had from an autozone or Napa?
The other thing is my tail lights stay on the whole time as if I were braking. Has anyone had that happen? I'm not real good with wiring but it seems to me like it should be something easy. Any ideas?
Thanks.
Thanks.
I use Royal Purple power steering fluid. Any Full Synthetic Power steering fluid will work. Valvoline Max Life is Semi Syn which is most available in auto parts will not be up to spec. I had to go with royal Purple b/c it was the only fully syn I could find. I think Risoline also makes a full syn fluid I had to use 4 pints @ $8 per pint it was $32 total. Pricey but no more wine in cold weather. I've not had a leak yet but I'm sure my time will come. There is a bleed screw on top of the steering box. You can attach a clear hose and a bowel to bleed out the system. If you use Royal purple, I just bled out the system till I, got all purple fluid, and then your done.
Did you replace the gasket that always goes bad on the back of the power steering pump? Or just add Permatex gray as a its own gasket
If your brake lights are staying on, most likely it is the switch. There is a switch that triggers the brake lights. It's located above the brake pedal. So when you hit the break, the metal part of the brake pedal releases the switch and the lights come on. Probably came loose or fell off. Look under the driverside steering wheel along the brake pedal (behind the cover) and see if you have a switch floating around. Hooking it back up is fairly self explanatory.
Snafu / Disco Fries
02-10-2011 01:13 AM
cherry
Off Topic
08-25-2008 10:15 PM
