Which u-joints are usually the culprit ???
Guys, been reading on the u-joint filures for a while now, and plan on having that job done next spring. My 2000 D2 has 57000 miles and the front u-joint on my front driveshaft is greasable, so I keep it greased up. My Disco had been in europe from 2002 to 2005 and the ex-owner had removed the cats while abroad.
My question is regarding which u-joints are usually the first to fail when they do??? the front one or the double cadran ones??? Which is the most common???
Ajh, did malmberg do all your u-joints on top of rebuilding your double cadran ??? Did you supply the u-joints and centering ball ??? How much???
Cause I called them last spring to have them do the job, and they said that they couldn't because they had absolutely no listing for Land Rovers.
waverider
Sep 29, 2009 08:27 AM
tornado_735
Mar 1, 2009 08:57 PM
rover
Freelander
Aug 8, 2007 11:28 AM
