Uh oh, fail
Old Jan 5, 2013 | 06:26 PM
AdrenalinPlease's Avatar
Default Uh oh, fail
I broke the bleed screw on the top T for the coolant system. Haha. Now what? Like now?
Also my temps after the flush are wierd but that may be due to the bleeder screw leaking. Cruising at 60mph I had 195.8F
Old Jan 5, 2013 | 06:28 PM
aarongregor's Avatar
so you twisted it off and the threaded part is in the t ?
Old Jan 5, 2013 | 06:32 PM
Yeah I over tightened it
I can probably remove the threaded part also
Old Jan 5, 2013 | 07:02 PM
jfall's Avatar
Replace the whole "T" fitting with new.
Anything else - and it will let go on the road if you try to fix it.
There is a known defect with the older "T" fittings.
OR
See if you can find a brass T fitting without a bleed screw and replace it.
I never use that damn bleed screw or ever touch it.
I bleed by raising the coolant tank - remove the coolant tank cap and run the engine at 1,200 RPM for 8 minutes. Then put in coolant to replace the air that got bleed out.
Put the tank back down - and done.
Others will disagree - but this works for me just fine.
Old Jan 5, 2013 | 07:03 PM
909wheeler's Avatar
Go to a BMW dealership and get a new one.
Where can I get it now?
Old Jan 5, 2013 | 07:14 PM
KindaGuitarded's Avatar
i just bought one at the BMW dealership a few weeks ago. It's about $3 and change. BMW part number 17-11-1-712-788.
Old Jan 5, 2013 | 07:22 PM
The actual screw?
Old Jan 5, 2013 | 07:24 PM
Yes, the screw... It was a temp fix. I ended up replacing the entire T fitting and upper hoses from the Stealership for around $123.
Old Jan 5, 2013 | 07:25 PM
jfall that really works?
