Ultra Gauge
Old May 26, 2013 | 09:16 AM
nvrenuf's Avatar
Default Ultra Gauge
I will be doing the Oil Pressure DIY in a week or 2. Ordering parts today. Will also order an Ultra Gauge. Question. Ultra Gauge is just pulling temp info from computer. So is the coolant temp accurate on Ultra?
I've seen the Temp Gauge DIY, and was planning on doing it. But, If I get an ultra gauge, do I still need to do the coolant upper hose, temp gauge DIY to accurately monitor temps? Or is it same thing basically? I'd rather not have to add 2 gauges (oil pressure/coolant temp) if not necessary. 1 gauge is clean. 2 become a little clustered.
Old May 26, 2013 | 09:27 AM
If you are going to add a plate for your oil pressure, consider also adding an oil temp gauge to the same sandwich plate. Oil temp is really more important then coolant temp.
And yes, the temp rad from your ultra gauge is accurate.
Rover_Hokie
Feb 2, 2014 03:52 PM
Discolife
Nov 23, 2011 07:58 PM
01d2Jeff
Nov 19, 2011 10:52 AM
Spike555
ROAMING WITH FRIENDS
41
Oct 24, 2011 06:26 PM
G Reeves
Oct 23, 2011 07:39 PM
