Trouble code from my ultra-gauge but no lights are on?
Old Nov 18, 2011 | 12:54 PM
01d2Jeff's Avatar
Default Trouble code from my ultra-gauge but no lights are on?
I plugged my ultra gauge in, and I'm getting a trouble code P1590.
what's odd is that none of the dash lights are illuminated?
when I clear the code, it just comes back immediately. Any ideas?
Old Nov 18, 2011 | 01:04 PM
01d2Jeff's Avatar
Originally Posted by jafir
Do the service engine, tc, abs, and hill decent lights come one and then go off when the car is started?
Nope. Should they?
Old Nov 18, 2011 | 01:05 PM
jafir's Avatar
Old Nov 18, 2011 | 01:06 PM
1590 is rough road detection out of range:
Rough road signal
When the vehicle travels across rough terrain, or on rough roads instability becomes evident in the drive train. The
ECM could interpret these vibrations as a 'false misfire'. To counteract this 'false misfire' the SLABS ECU generates
a rough road signal, sends it to the ECM so that the ECM can suspend misfire detection for as long as the vehicle is
travelling on the 'rough road'
see these pages from RAVE
File Type: pdf
Old Nov 18, 2011 | 01:07 PM
01d2Jeff's Avatar
Rough road signal
So, it's normal for the ECM to throw this code? Should any lights illuminate when it happens?
EDIT: I just went and checked - when I start it, the check engine light cycles (just like the Brake light, seatbelt, etc...), but no HDC light or ABS light.
Old Nov 18, 2011 | 10:29 PM
DaveBFoto's Avatar
$5 says your ABS/TC/HDC bulbs are removed and you have the 3 amigos
Old Nov 18, 2011 | 10:30 PM
Double or nothing!!!
Old Nov 18, 2011 | 10:32 PM
What these guys said, this is so common with DII's to have those bulbs removed (they are actually LED's and they break them so they dont work anymore) that I try to ask people if those lights come on when they are test driving a truck.
Old Nov 19, 2011 | 06:20 AM
01d2Jeff's Avatar
That would be my luck. So what's my next step? Anyone in the Chicagoland area have an amigo code reader?
Old Nov 19, 2011 | 06:24 AM
01d2Jeff's Avatar
Here's another question - would a leaky caliper cause the 3 amigos?
