Finally got my ultra gauge up and working. However, i get an alarm for pending trouble codes P0150 and P0174 every couple minutes. I don’t have a check engine light. Is it potentially warning me some things are on their way out? Or is my ultra gauge the problem?
The conditions that may eventually lead to the Service Engine Soon light coming on.
Given those pending codes, you may have a Bank 2 upstream O2 sensor replacement in your near future.
Since you have an UltraGauge, you can set up a page to monitor O2 sensor activity real-time.
Here's a pic of the O2 monitoring page I have set up on my truck. Output volts are at the top for each cylinder bank, with short-term and long-term fuel trims in the four spaces below. Monitoring even just the O2 voltages would give you a window into what is triggering the pending codes.
