Ultra Gauge re-design
Who thinks the makers of Ultra Gauge should re-design their product? It's a reasonably priced piece of equipment which gives you mind peace on temperatures. Although, I would like to see them re-design the front panel and have the three buttons more accessible by adding them to the front.
The velcro solution works but after pulling the U.G. off multiple times it pulls the velcro off the unit.
I'd be willing to pay more for a button front displayed unit. Just a thought.
I don't know... I kind of like the sleek look it has without the buttons on the front. I guess it all depends on where you mount it, though. I have mine mounted just above the right side of the driver's console. Directly above the 3 switches. Easy to see and easy to still use the buttons. I used 3M adhesive double sided tape to mount the bracket to the dash. If I need to pull the gauge off, just unclip from the bracket and it's free.
I wonder if they could come up with a way to put the buttons on the side of the gauge? It may make it a bit thicker, though.
For another $20, they could add touch screen... That would be my preference.
THEN, I'd incorporate it into my dash, console, or overhead. I've been tempted to, and may end up opening it up and adding leads so I can have exterior buttons for flush mounting somewhere.
I personally also do not like the buttons on the back side. But then again I hardly ever need to touch them anyway.
And besides, not to be the sore thumb here but what does the U-G have to do with a DII, specifically? Just observing once again, misplaced threads = harder to find information for those seeking it.
Find my thread HERE about my UG and GPS installs.
I think the UltraGauge is specifically linked to the DII due to the Overheating stigma the DII has. As such, people are most likely to eventually add one to their DII. And, we are always looking for ways to make this installation as natural looking as possible so it appears to be part of the Stock Gauges.
And honestly, I expected U-G to be a little bigger when I purchased it. Received it and I was a bit surprised how small it really is.
There is a touchscreen mod for the Ultragauge. Using some Lexan or plexiglass or something solid behind the gauge. When you push on the corners of the gauge it will give just enough to activate the rear push buttons. You can test this easily by placing your ultragauge on a flat surface and pressing the corners. You can feel the buttons activate. Here is a video demonstration of the mod. Skip to about 1:17 of the video.
