unclogged a/c drains, still have water on passenger floor
Old Dec 15, 2008 | 10:19 AM
hazletbassist89's Avatar
Default unclogged a/c drains, still have water on passenger floor
Actually I didn't really unclog them, I looked up at them with a flashlight from under the truck, they looked totally clear as far up as i could see, so I ran some metal wire up there anyway but found nothing. Why do I still have water all over my passenger floor all the time?
Also, where exactly do the sunroof drains lead? I couldn't find them anywhere near the front wheel wells, and my sunroof drains are leaking too.
Old Dec 15, 2008 | 10:27 AM
sloppyjoe's Avatar
Default RE: unclogged a/c drains, still have water on passenger floor
where is the sunroof drain?
Old Dec 15, 2008 | 11:21 AM
Urban Panzer's Avatar
The sunroofs quite often leak between the tray and the roof as the factory seal Land Rover used was a useless bit of pathetic foam. The only fix for that if its leaking there, is headlining out, sunroof assy's out and re-seat them on a good bed of silicone / RTV sealant.
Old Dec 15, 2008 | 12:57 PM
If it is the condinsation from the a/c that is not flowing thru the drains, then they are not unplugged. When unplugged they will not drain water from under the carpet, that is your job, they will only drain water trapped up in the evap system.
If you have water on your floor, you should get a shop vac, pull the carpet up along with the pad and remove as much water as you can before mold starts growing. I would suggest spraying some Lysol on the floor, the pads and the back side of the carpet to limit the potential smell.
Old Dec 15, 2008 | 01:28 PM
Will do Mike. I guess that's what I'll do when I get off from school next week. I'm thinking about pulling out all the carpets and headliner and putting herculiner (cheap rhinoliner) on all of it. It's going to be a trail truck in the long run anyway.
Old Dec 15, 2008 | 01:38 PM
Just a word of caustion, once you remove the headliner the db's inside the cabin will increase, and then once you remove the carpet the db's will double again and you wont be able to talk to your passenger.
Old Dec 15, 2008 | 01:53 PM
Yup, I plan on it. Can't wait to get that resonator off the back of the exhaust too!
Old Dec 15, 2008 | 02:02 PM
What? I cant hear you!
Old Dec 15, 2008 | 02:17 PM
rofl it'll be something like that when it's all done
dougn
Dec 4, 2012 06:25 PM
SStrobel
Sep 28, 2012 03:24 PM
Princess
Sep 15, 2009 08:02 PM
sharp
May 17, 2009 05:36 PM
rjaime6
Jul 12, 2008 10:53 PM
