Under-hood Chirp, Condenser Fan?
I have a 2004 Se7 80kmi and it has had only a couple of problems so far. The first being a chirping sound like a cricket from the front of the car, it seems to be coming from the condenser fan. I have read all over that people say it's belts and pulleys and I have not found anything saying that that fan makes that noise or many people having trouble with it. If that is the case how much can I look at for replacing it and are there alternatives. Also there is a knocking/tick that's pretty steady and does not really increase too much with acceleration. If the vehicle is at idle or in neutral it really does not do much of anything as far as changing speed of the tick/knock. It seems like it's coming from the bottom of the car, more than likely an exhaust leak but still an opinion would be nice. Thanks in advance for any input!
I plan on crawling under the truck tonight and checking all of the bolts etc. I guess it could be the belt but it just seems like a strange noise for a belt to make, it's not a high pitched squeak it sounds just like a loud cricket chirping. I will take your advice and go ahead and replace the belt this week, thanks!
yeah mine did the same thing and it was the belt.No problem glad i could help let me know what u find with the tick/knock
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
Well I finally got everything checked out and this is what I have found. The ticking was a mainly an exhaust leak which turned out to be some loose bolts. I did get my oil changed a few days ago which produced another ticking that turned out to be coming from the drivers side valve cover and this is verified by my trusty screwdriver and ear. The chirping sound was not the belt and turned out to be the condenser fan (the fan behind the grill on the radiator) after all. So now I need to find a good replacement and time to pull that little troublemaker out. I figured I would throw out an update and see if there were any suggestions for type of fan and should I also flush my engine out to see if it quiets that tick or is it just a part of life now?
