under hood insulation liner drooping
Hello,
My Disco 1 insulation liner that is mounted on the underside of the engine hood is drooping mainly over the center to back of the top engine. It is touching the top of the retangular piece that sits on top that says Land Rover 4.0 on it. Sorry, I don't know the official term for it.
I pushed on the liner and there was a good bit of distance between the hood and the liner. My hand could almost fit behind it.
Is there an adhesive that could keep it stuck to the hood. My concern is the high heat level could release the bond that keeps the liner stuck to the hood.
It looks like they didn't put one of those big round tabs in that critical area.
Any suggestions that could keep the liner away from touching the top of the engine?
Thanks.
chrisusvi
Thanks.
chrisusvi
If you never want to be troubled by it again... try this stuff:
http://www.tooled-up.com/Product.asp...nt-Black-310ml
I know of one company in the UK that uses this to glue and seal the coachbuilt bodies of motorhomes to the chassis with it - one serious adhesive and it's temperature, water and oil resitant. Has a pungent acetic acid (vinegar) smell during and shortly after curing.
Hope that helps,
Hope that helps,
adhesive, discovery, drooping, engine, hood, insulation, insulationadhesive, insulatior, land, liner, liners, pad, range, rover, underhood
