under hood insulation liner drooping
Old Sep 22, 2007 | 11:59 AM
chrisusvi's Avatar
Default under hood insulation liner drooping
Hello,
My Disco 1 insulation liner that is mounted on the underside of the engine hood is drooping mainly over the center to back of the top engine. It is touching the top of the retangular piece that sits on top that says Land Rover 4.0 on it. Sorry, I don't know the official term for it.
I pushed on the liner and there was a good bit of distance between the hood and the liner. My hand could almost fit behind it.
Is there an adhesive that could keep it stuck to the hood. My concern is the high heat level could release the bond that keeps the liner stuck to the hood.
It looks like they didn't put one of those big round tabs in that critical area.
Any suggestions that could keep the liner away from touching the top of the engine?
Thanks.
chrisusvi
Old Sep 22, 2007 | 06:23 PM
Default RE: under hood insulation liner drooping
Get some 3M adhesive and glue it back up.
Old Sep 22, 2007 | 07:37 PM
Adz's Avatar
Adz
If you never want to be troubled by it again... try this stuff:
http://www.tooled-up.com/Product.asp...nt-Black-310ml
I know of one company in the UK that uses this to glue and seal the coachbuilt bodies of motorhomes to the chassis with it - one serious adhesive and it's temperature, water and oil resitant. Has a pungent acetic acid (vinegar) smell during and shortly after curing.
Hope that helps,
CollieRover
Jan 29, 2023 12:47 PM
mpcrnc
Mar 5, 2016 11:56 PM
bcolins
Aug 16, 2014 10:40 AM
Jay5oh
Mar 19, 2010 03:26 PM
jdelp
Apr 22, 2008 12:20 PM
