Undercoating / Rust Prevention
Old May 17, 2017 | 07:32 AM
zoltan7's Avatar
Default Undercoating / Rust Prevention
Guys,
Has anyone tried coating the frame / drivetrain? I'd like to at least paint my underbody to make it look a little bit better.
I've never done such a thing before, so I have no idea what's involved. I assume its a very labor intensive process to do.
I supposed I could start with the easier stuff (removing an axle at a time and sanding / painting them).
I also assume I can't just go under there and have at it with a rattle can lol
Any advice / feedback from those with experience in the matter would be appreciated.
Thanks
Old May 17, 2017 | 07:54 AM
dgi 07's Avatar
Undercoating.......comes from my leaking engine. Best rust prevention ever.
Old May 17, 2017 | 08:03 AM
zoltan7's Avatar
Well played lol very well played
Old May 17, 2017 | 09:15 AM
Best4x4's Avatar
Yep a leaky transfer case with 85/140w oil puts a nice thick coat of protection on the rear frame, axle, drive shaft, shocks, coil springs, and gas tank skid lol.
Old May 17, 2017 | 09:45 AM
Mskembo's Avatar
I too have a fresh coat of oil on my undercarraige, but plan on using POR15 on the rails to get them cleaned up. It's just time consuming and needs to done carefully so there isn't a huge mess. I'm also looking at options to lift the body off of the frame 12-18 inches in order to get access to the top of it. Of course then i would want to replace all the body mounts too... It never ends.
Old May 17, 2017 | 12:41 PM
KernowDiscovery's Avatar
I've used a rattle can in the past, in fact I'm planning on doing it again next weekend. Rustoleum matte black. I'm sure it's not as good as taking everything apart piecemeal and coating it but I really don't have the patience or the pocketbook for that. So me and my rattlecan will get real intimate with the underbody of Bertha in a week's time The last time I was under there I noticed a chunk of metal missing off of the underbody (rust) - I need to find someone to weld a plate on in that place.
good luck!
Old May 17, 2017 | 12:51 PM
zoltan7's Avatar
Do you guys sand or grind anything off? lol or just spray and pray??
Old May 17, 2017 | 12:54 PM
acg's Avatar
acg
Do a search for waxoyl, dinitrol & land rovers.
https://www.youtube.com/results?sear...oyl+land+rover
Old May 17, 2017 | 01:24 PM
Mskembo's Avatar
That's what I need to do... but it looks like way too much work.
Old May 17, 2017 | 01:29 PM
zoltan7's Avatar
Wow
USA HQ for Dinitrol is right down the road lol score!!!
