unfaithful starter
Old Sep 21, 2014 | 10:37 AM
sdaigs's Avatar
4th Gear
Default unfaithful starter
Towed my discovery II home. It would not start, battery good. Banged on starter and now it works. I am going to replace the starter but why does beating on it work?
Thanks
Old Sep 21, 2014 | 10:44 AM
RicketyTick's Avatar
Thanks
Did you check that all of your connections are tight?
Old Sep 21, 2014 | 01:55 PM
cappedup's Avatar
Starters you have to bang. Either stuck, and banging frees it. Or it's a connection and by the time you've find something to bang it and knocked stuff around it magically works.
Defo check connections first.
Are starters easy to get to on these?
Old Sep 22, 2014 | 06:52 AM
chicane's Avatar
Exclamation
Here is my experiences with a starter issue. I bought my truck recently with service records and they indicated the starter was recently replaced and had only 300 miles on it. I had starter issues almost immediately after buying it. After doing all electrical diagnosis I concluded that there was no problem with the battery or connections so I proceeded to remove the starter. When I pulled the starter I saw that the Bendix cover was shredded. The tolerances with this starter were off causing interference with the flywheel.
Of course it was some el-cheapo no-name starter so I proceeded to exchange this for a re-manufactured Bosch starter. Put that Bosch starter in and my truck has gone thousands of miles starter-trouble-free.
Lesson: Do not use cheap parts in your vehicle use Bosch, OEM, or other name brands recommended on this board and you can save yourself a lot of grief.
Old Sep 22, 2014 | 08:00 AM
redrover75's Avatar
I thought I had a similar issue, the start is fine. Turns out there is an electrical glitch so that when i lock and unlock via the key in the door the car starts right up.
Just an observation for you.
patrolman4
Nov 6, 2023 07:48 AM
sna77
Sep 16, 2023 08:10 AM
Gimebakmybulits
Jul 14, 2014 05:57 PM
johnkbl
Apr 23, 2012 07:49 PM
hsmatharu
Defender
Aug 23, 2006 12:33 AM
