Unknown oil port and plug
Old Jul 22, 2013 | 10:25 AM
mtrionfo's Avatar
Default Unknown oil port and plug
While changing the oil and filter this weekend on my 03, I noticed that a threaded plug located near the oil filter housing was dripping a little oil. After cleaning it off I could also see it was not fully seated. I tried to tighten it but it felt like it was bottoming out even though 2-3 threads were still exposed. I unscrewed it, cleaned everything up and tried again but same result.
I've done three or four oil changes on this truck since I bought it in March but I never noticed this plug before. I'm wondering if the previous owner put the wrong size plug in there? It threads in smoothly but definitely bottoms out early.
Here are a couple of pics. Any idea what this port is for and if this is the correct plug? Thanks.
Old Jul 22, 2013 | 10:30 AM
drowssap's Avatar
I could be left over from when LR used to put oil coolers on DiscoII's
Old Jul 22, 2013 | 12:29 PM
Madlands's Avatar
I noticed the same one on my 04 yesterday while I was under it admiring all my leaks. Mine was also leaking a tiny bit and wasn't seated flush either, but I'm sure it's all the way in.
Old Jul 22, 2013 | 12:44 PM
caymandrew's Avatar
Yes, that is one of the two connections that pumps oil to the front oil cooler on my 2001. You just have plugs on 03's and 04's because they removed that system.
Old Jul 22, 2013 | 12:49 PM
caymandrew's Avatar
If you need a replacement plug they are 3/4" thread count 16.
Old Jul 22, 2013 | 01:10 PM
mtrionfo's Avatar
Excellent. Thanks for the plug detail.
I found this one on the RockAuto site: Dorman Oil Drain Plug which looks like it will fit much better. Cost is $3.60 each.
Thanks.
Old Jul 22, 2013 | 01:18 PM
ralphobell's Avatar
Great spot to put an oil pressure sending unit in the future.
Old Jul 22, 2013 | 01:43 PM
mtrionfo's Avatar
And a little searching turned up this thread from 2010 where someone did exactly that. Looks like he used the other unused oil cooler port than the one I found (next to the filter), but it's got the same size plug in it. And from the clean vs dirty threads it also looks like it wasn't fully seated. Go figure.
Oil Pressure Sending Unit Install
Old Jul 23, 2013 | 08:58 AM
drowssap's Avatar
that one has no pressure it is the return from the cooler and can not be used for a oil pressure switch
Old Jul 23, 2013 | 10:53 AM
he good new is you can, if you don't have a oil cooler, buy a used one and still install it to have a cooler running engine.
An yes, you can not install a pressure gauge to that port, because as mentioned it was the return line fitting.
