Upper Intake strange washer
Old Jan 20, 2017 | 04:42 PM
sayeedA's Avatar
Default Upper Intake strange washer
I am trying to put upper intake back. does anyone know where that thick washer goes to?
Old Jan 20, 2017 | 04:56 PM
sayeedA's Avatar
i looked little seems like #10 spacer
Intake Manifold, Top End, Engine, Discovery II - Rovers North - Classic Land Rover Parts
The spacer does not go through any of the bolts! help stuck
LR03NJ's Avatar
You have some extras. 4 long in middle and 2- front and back. Vaccum clamp?
The other seems to be a non rover bolt.
Old Jan 20, 2017 | 05:03 PM
sayeedA's Avatar
Originally Posted by LR03NJ
You have some extras. 4 long in middle and 2- front and back. Vaccum?
when I took out I put in a baggy. its a 1/4 in thick metal spacer.
Old Jan 20, 2017 | 05:16 PM
LR03NJ's Avatar
that might be for the cacuum clamp on top
Old Feb 4, 2017 | 08:36 AM
wpratt70's Avatar
3rd Gear
Funny, I'm in the same boat. I had the 4 long and 2 short bolts in a bag with a thick spacer. I cannot for the life of me figure out where it goes. Did you determine where by chance?
Old Feb 4, 2017 | 08:39 AM
LR03NJ's Avatar
Upper manifold. 4 in the middle and 2 front and back
Old Feb 4, 2017 | 09:25 AM
BackInA88's Avatar
The spacer goes between the intake and the support bracket on the tubes to the heater core on the right side of the plenum.
Mine has a stud were it mounts I find it easier to remove the stud when installing the upper plenum. Then secure it afterwards.
The short bolts? Idle air control mounting clamp? EVAP?
Old Feb 6, 2017 | 01:34 PM
wpratt70's Avatar
3rd Gear
Thanks BackInA88! I was starting to wonder if that is where the spacer went. The bolts I was fine with but that stupid spacer was an irritation.
Old Feb 6, 2017 | 03:47 PM
OffroadFrance's Avatar
Well spotted Sayeed.
Now is to find where exactly it goes
