Upper Radiator Hose - tired of changing
Old Jan 23, 2017 | 11:03 PM
sayeedA's Avatar
Default Upper Radiator Hose - tired of changing
After got tired of dealing with thee Plastic bleed screw I decided to replace them with Home depot hardware. see the picture.
I have seen similar works with some sort of Brass bleeder.
Does anyone have an instruction how to do that and measurements?
Also do you have to buy all 3 hoses? can you order the top piece only that goes to Radiator only?
Thanks
Attached Thumbnails Upper Radiator Hose - tired of changing-unnamed.jpg   Upper Radiator Hose - tired of changing-unnamed-3-.jpg
Old Jan 23, 2017 | 11:28 PM
Bom2oo2's Avatar
Man, the way you tightens those hose down will make them burst pretty soon, the connection ends appear too small for at least two of them, and clamps are squeezing hoses far too much,
If you need the longer hose to radiator, then yes you need to buy all 3, but if you need any of other 2 you can buy any 90* bent hose that inside diameter is 1.33" =34mm and long enough,
Old Jan 23, 2017 | 11:39 PM
sayeedA's Avatar
You are correct. They look funny. I think I used short threaded pipes as extension. Its been a while. these are what I used. I think I am going to redo. The challenges is to out the bleeder.
Anyone have instructions?
Thanks
Attached Thumbnails Upper Radiator Hose - tired of changing-6101422.jpg   Upper Radiator Hose - tired of changing-6125207_1.jpg
Old Jan 24, 2017 | 01:56 AM
DailyDrivenTJ's Avatar
I avoid worm gear clamps because they are not under tension by themselves. If the diameter of the material it is holding changes/reduced the tension is no longer applied.
Whereas the true tensioners are designed to exert tension within a range of diameters so even if the diameter of the hose shrinks, it still exerts tension.
Only time I would use worm gear type clamp is when it is incredibly major PiTA to place the tensioner.
Old Jan 24, 2017 | 07:49 AM
LR03NJ's Avatar
Thanks
I use a similar home depot part and the ends wont be tapered as the NPT style pipe ends.
Land Rover and Range Rover Picture by LR03NJ | 6815514 | LandRoverForums
There is one also at ebay made with aluminum with the bleed screw
Land Rover Discovery 2 Coolant Hose "T" connector
Old Jan 24, 2017 | 08:15 AM
redrover75's Avatar
Default Galvanized
I cant believe that the galvanized pipe is the best solution. What about copper? Stainless, some other less chemically treated metal. There has to be reason there is no galvanized steel in contact with fluids.
Old Jan 24, 2017 | 09:34 AM
jamestfl's Avatar
Thanks
why not do the inline thermostat mod? The entire mod costs about the same as the upper hose assembly (speaking from first hand experience )
Old Jan 24, 2017 | 10:28 AM
sayeedA's Avatar
I have been reading about that too. is there any benefit doing so? you can get the upper assembly for less than $30 bucks
do you have the instruction and parts needed for it?
Old Jan 24, 2017 | 10:30 AM
sayeedA's Avatar
The ebay one looks perfect but $100 for a T-pipe is over the board.
Old Jan 24, 2017 | 02:36 PM
OverRover's Avatar
That part is only "$100" if you are paying in Canadian $$.
