URGENT ASSIST: Front hub nut
Old Jul 24, 2014 | 08:36 PM
chicane's Avatar
Exclamation
Originally Posted by Paul Grant
If you don't have air tools and can't seem to loosen the nut with your normal breaker bar go find a 4 or 5 foot pipe and follow this guys instructions.
I just broke TWO breaker bars using this method, including my favorite that I had for 15 years.
Old Jul 24, 2014 | 10:13 PM
ZGPhoto's Avatar
I feel like reading this thread has made me realize how really attached you were to that breaker bar!
On a serious note, buy the $40 electric half inch impact wrench on harbor freight, it'll pay for itself the first day. You think that nut is hard? Try a tdi flywheel removal...... anyways, buy it!
Old Jul 24, 2014 | 10:26 PM
chicane's Avatar
I already have it, it did absolutely nothing.
Old Jul 24, 2014 | 11:34 PM
Colorado David's Avatar
If I thought I was going to do very many hub nuts, I'd buy a 3/4 drive breaker bar and appropriate socket. Then I'd add a cheater with some confidence.
Old Jul 25, 2014 | 08:08 AM
dusty1's Avatar
^ agree.
your favorite breaker bar was not up to task. get one that is. you can get impact reducers, so you don't have to get new socket. go to plumbing section at hd and get an extension pipe. if you are a featherweight, get a long one and stand on it. bounce. don't forget to pop up the divot.
1 1/4" fits better....less slack
Old Jul 25, 2014 | 09:36 AM
chicane's Avatar
I have one (and a cheater, which I used with my 1/2 bars) What I didn't have was a 3/4 drive 1 1/4 (32mm) socket. And no one had one in stock.
Old Jul 25, 2014 | 09:39 AM
chicane's Avatar
Originally Posted by dusty1
^ agree.
I looked for a 3/4 drive to 1/2 drive reducer they are not that common and are relatively hard to find even online. And even with that the reducer might not be up to the task (the weak link in the chain), AND there is a time element here, I need the truck ready for this weekend. I have a pretty well stocked professional box for a home enthusiast. Hindsight is 20/20. I am neither a light weight in body or experience. The problem isn't the mechanic it is this truck.
Old Jul 25, 2014 | 09:47 AM
dusty1's Avatar
I wasn't questioning your heavyweight abilities. just saying I am at 230lbs, so it makes it easier with the help of less gravitational pull.
you can go to hf and get reducers 3/4 to 1/2......get a couple if you want to have a spare. cheap. the whole set is just the price of a cup of coffee.
you did pop up divot?
Old Jul 25, 2014 | 11:51 AM
chicane's Avatar
Ok he got the nuts off and then, I don't know how located the new nuts in the center console of my truck (i told them to just put the old ones back on), installed the new nuts and indented the safety detent.
Can I back these out and reuse?
Old Jul 25, 2014 | 12:59 PM
Yes. I just reused one on a rear hub this morning.
